Idle adjustment knob
Old 03-29-2012 | 11:40 AM
navd's Avatar
navd
Well that would make a ton of sense John!
Old 03-29-2012 | 04:18 PM
cHarley's Avatar
cHarley
Yep, that's just a relocated choke **** in the video. It sticks out ridiculously far IMO.
Old 03-29-2012 | 04:37 PM
xFreebirdx's Avatar
xFreebirdx
Old 03-29-2012 | 04:43 PM
John Harper's Avatar
John Harper
That's an interesting item, for sure. Still not sure why you need to worry about idle speed after it's adjusted. I guess it's for those of us who just love extra ***** to turn and buttons to push.
John
Old 03-29-2012 | 04:52 PM
cHarley's Avatar
cHarley
John
Because some people actually ride far enough to change climates. A couple of time a year, I go from 90+ degree flat-lands to freezing temps at 6,000+ feet. The idle mixture and then as a result the idle speed, get tweaked every time I do.
Old 03-29-2012 | 04:54 PM
John Harper
Quite right, forgot about that. Of course, I'm just a flatlander down here on the beach in SoCal.
John
Old 03-30-2012 | 06:03 AM
trmac's Avatar
trmac
Big Kahuna HDF Member
Originally Posted by navd
I guess I was a little vague,
I'm talking about the **** sticking out the top of the carb in this crazyorange video:
http://www.youtube.com/embed/q5eS86tgH8U
I believe it would be something along the lines of this:
http://www.debrix.com/CV-Carburetor-...35-0157-vt.htm
And for the record I've got a '92 - which of course has a carb.
I've got one like that. The one in the vid looks like the idle and not the choke.
Makes it nice for cold starts - turn up the idle a bit and you can push the choke back in without having to mess with the throttle lock. Real easy to turn back down after its warmed up and you're on the road.
Comes in real handy with the changing temps and atmospheric conditions.
Pretty easy to put on. Remove the idle screw (be sure to go slow and watch the spring) then screw the **** in.
I recommend pulling the AC (back plate too) off to give some working room - easier to catch that spring too. I spent 15 min looking for spring and getting it out of where it went. Had to rig a bit of wire and a zip tie to keep from bouncing against the tank.
Old 03-30-2012 | 08:01 AM
guitarman023's Avatar
guitarman023
bingo
reservoir dog
EVO
11-09-2013 02:38 PM
HarleyReece
EVO
20
06-26-2012 07:58 PM
nwpwr22
Ironhead
05-30-2012 04:15 PM
RidemyEVO
EVO
07-31-2010 10:06 AM
maineultraclassic
Exhaust System Topics
07-23-2009 10:00 PM
Quick Reply: Idle adjustment knob
