I dont think so the coil is under the mount and the tank goes away from the tunnel so that should be fine and the key is lower then the tank should go but Ill put it on Sunday and let you know. I do know you need to run the fuel line to the opposite side of the carb since it switches sides and I might have to relocate my blinkers to the forks and you have to have at least a 4 inch riser on your bars.
