Exhaust leak after fwd control install?
Old 03-26-2012, 01:54 PM
SpecterGT260's Avatar
SpecterGT260
SpecterGT260 is offline
Default Exhaust leak after fwd control install?
I put my fwd controls on a couple weeks ago and had to remove the front pipe to get at the brake-side components. I do not recall there being a gasket so when finished I just put the pipe back in place on the head and bolted it down. I may be paranoid but I feel like I hear a tic now. Is a gasket replacement necessary if you unbolt the header from the head for any reason?
Old 03-26-2012, 02:04 PM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
It's hit and miss on the old gasket sealing up. Any time I have ever removed and exhaust I always replaced the gaskets with new. Just some cheap insurance. You may also want to try and re torque the pipe and see if that helps.
Old 03-26-2012, 04:01 PM
cHarley's Avatar
cHarley
cHarley is offline
It's wise to always replace the manifold gasket when you R&R an exhaust pipe. The gaskets are pretty cheap and it's not worth having to redo the job if it leaks.
I keep spares on-hand just like I do oil, oil filters, spark plugs, bulbs, etc.
Old 03-26-2012, 10:34 PM
aklim156581's Avatar
aklim156581
aklim156581 is offline
I don't reuse condoms or gaskets.
http://partsfinder.onlinemicrofiche....dmc&A=745&B=48
Item 22 and 24 if I am looking at it right.
Old 03-27-2012, 07:24 AM
SpecterGT260
I'll make a trip down to the dealer this afternoon. The headers are fairly simple to pull off and on so no biggie. thanks :thumbup:
Old 03-27-2012, 07:34 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
gaskets I understand that....but condoms, you can just turn them inside out and use them again....
Old 03-27-2012, 07:44 AM
schwingding's Avatar
schwingding
schwingding is offline
Right! Same way I get two days out of underwear, and socks.
Old 03-27-2012, 08:25 AM
SpecterGT260
Just throw them against the wall. If they don't stick they are good for another round
(good for all of the above)
Old 03-27-2012, 10:30 AM
aklim156581
Never tried that myself but I haven't had to use one in a LONG time. LOL
Old 03-27-2012, 10:31 AM
aklim156581
Underwear you can get 4 uses.
Quick Reply: Exhaust leak after fwd control install?
