04 Sportster 883 Carb issues
Old 03-26-2012, 09:33 AM
racin45's Avatar
racin45
racin45 is offline
try alittle ethenol additive to remove the crap and try that ... my 96 1200 eased up the *Sneezing issue* since i started using that
Old 03-26-2012, 10:32 AM
jeffreycarter87's Avatar
jeffreycarter87
jeffreycarter87 is offline
1st Gear
I did disassemble the carb and thoroughly clean it but did not check for air leaks... It happens just about any time im a stop light or in traffic when I crack the throttle, not ever under load, my next plan is to replace the seals and see if that works.
Old 03-26-2012, 12:17 PM
jeffreycarter87
1st Gear
I disassembled and cleaned the carb but didn't check for air leaks cause I figured the cleaning would take care of it, it happens pretty much anytime I'm at idle like ata stop light or in traffic when I crack the throttle. My next step is to replace the seals, might as well do it anyway because it has sat for so long.
Last edited by jeffreycarter87; 03-26-2012 at 01:05 PM. Reason: Didn't realize I sent that already
WAM2
05-31-2017 07:55 PM
sven556
01-29-2015 01:59 PM
HarshMC
06-04-2014 08:29 AM
HDSport
02-14-2012 07:10 PM
TimBob2010
11-15-2009 07:51 PM
Quick Reply: 04 Sportster 883 Carb issues
