front fork leaking
front fork leaking
Hey looking for some help,just went out to the garage to fire up the bike now that the weather is getting better.Noticed a pretty giant puddle under the left( if your sitting on the the bike) side fork up front. cant seam to figure out where its coming from, there's no drip marks, and no run trails down the tube. Its red fluid, the forks were changed to chrome before i owned the bike. any help would be great
+1 on the drain screw
Hopefully your drain screw hole isn't stripped. One of the many bad things about chrome parts is that most of the threads need to be chased before installation and not many ppl do.
HAhah! thank you guys for the help went and checked the drain screw and the screw was loose and there was no crush nut and as soon as i touched it it was a steady drip which leads me to believe its stripped to a point because it has movement while "threaded in". thank you guys, ill probably check and go over everything anyways just to be safe. One more thing, is there a specific way to add fluid to the tubes? I'm hearing different ways and opinions from different people.
