OIL Check
Old 03-24-2012, 10:53 AM
JLCKB's Avatar
JLCKB
JLCKB is offline
Stage II
Default OIL Check
Just bought my first HD, 2004 Sportster 883 Custom. Need some help as I'm new to Harley Davidson and the bike did not come with and owners manual. How do I check the oil on this bike?, Jiffy stand or straight up at 90 degrees.
Also how often do I check oil and whats the best way to get dipstick out after you pop the cap up?
I'm assuming you add oil in the same place as the dipstick.
Thanks for any advice.
Old 03-24-2012, 10:55 AM
LucyOnBlack's Avatar
LucyOnBlack
LucyOnBlack is offline
oh oh ... welcome on board JL
Old 03-24-2012, 10:58 AM
JLCKB's Avatar
JLCKB
JLCKB is offline
Stage II
Thanks...rode a rice burner years back...always wanted a Harley.
Old 03-24-2012, 11:52 AM
tripn88's Avatar
tripn88
tripn88 is offline
Position motorcycle so that it is leaning on jiffy stand on level ground.
Old 03-24-2012, 12:01 PM
cHarley's Avatar
cHarley
cHarley is offline
The oil level should always be checked when the motor is still hot/warm. Checking and adding oil after the bike has been sitting will result in an over filled tank.
When checked with the bike on the jiffy stand, add oil up to about half way between the ADD and FULL marks on the dipstick. After doing so, if you check the oil again with the bike in the upright (normal riding) position, you'll find the level on the dipstick will read between 3/4 and Full.
Running the bike with the oil level at the Full mark usually results in oil being puked out of the breathers and into the air filter can.
Old 03-24-2012, 12:57 PM
Bigspag's Avatar
Bigspag
Bigspag is offline
First buy a manual
Old 03-24-2012, 04:08 PM
John_K's Avatar
John_K
John_K is offline
Originally Posted by Bigspag
First buy a manual
Except ignore what it says in the manual about how much oil to put in because it's wrong. It states 3.6 quarts, should be 2.8
Old 03-24-2012, 05:45 PM
mdpbowtech's Avatar
mdpbowtech
mdpbowtech is offline
Stage IV
really only 2.8?
i bought my 04 manual online for $25. I do suggest you get one
Old 03-24-2012, 05:50 PM
tripn88's Avatar
tripn88
tripn88 is offline
Yeah thats about right. I put a quart in my trans, then 2 full quarts. Then rode around checked it again and added almost a full quart. It was perfect.
Old 03-24-2012, 06:05 PM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by mdpbowtech
really only 2.8?
Yep, the 3.6 quarts listed in the Owners Manuals up until around 08?, is for a factory new, DRY motor.
An oil change should only take about 2.75 quarts, depending on the size (capacity) of your oil filter and how high you run your oil level on the dipstick.
Quick Reply: OIL Check
