Feed Line on evo sportster oil pump?
Running oil lines on 02 evo sporty in a custom frame. I'm not real familiar with the sportster oil pump. Can some one tell me which line on the oil pump is the feed line? I don't want to guess. Is it the one on the top of the pump or the bottom facing the rear of the bike? To make matters worse it has an aftermarket softail style oil tank and I'm still trying to figure out which line is the feed line on the tank. The only ones I'm 100% positive of is the drain and the vent. that still leaves 2 to choose from. thanks in advance.
Best I can tell from the '06 manual, the feed line is the lower, rear facing port on the pump, fed from from the lower, right front of the tank. The pressure line is directly opposite facing forward. The return line from the scavenge section is the upper port facing forward/right, with the 90 elbow and hose wrapping around back to the left bottom of the tank. Vent line connects at rear of tank.
