Good Lord these older Sportys must be easy to steal! Replace lock switch?
Old 03-03-2012, 09:54 PM
Wakko47's Avatar
Wakko47
Wakko47 is offline
Default Good Lord these older Sportys must be easy to steal! Replace lock switch?
I had to pull the horn/lock bracket assembly today and realized just how damned easy it'd be to hotwire the bike. Someone with a little bit of knowledge could defeat the fork lock padlock with some freon, or just cut the aluminum bracket, then use quality alligator clips to bypass the ignition lock and voila, ride it home.
Any of you guys ever replace the lock with anything? I'm not overly concerned about my bike, it's older and insured, but I'd bet the guys with really nice bikes would be concerned about it. My lock bezel is pitted, so if I swap it out I'd look for something with a bit more shrouding of the back of it.
Old 03-04-2012, 06:14 AM
nc883's Avatar
nc883
nc883 is offline
Locks are only made for law-abiding citizens. If somebody wants it bad enough, they'll get it no matter what amount of protection. To directly answer your question, I looked in to more security for mine, and other than an alarm system, I couldn't find anything I was satisfied with.
Old 03-04-2012, 06:23 AM
cavalier2000's Avatar
cavalier2000
cavalier2000 is offline
Sadly alarms are near useless now-a-days. Hell most car alams don't have an ignition cut off so you just pop the hood and disconnect the battery for a few seconds and it resets.
A rotor lock is nice, but really it's a motorcycle, two dudes can pick it up and put it in the back of a truck if they wanted.
You could try a "dead man's switch" just a simple on off switch thats hidden. with it off the bike has no power
Old 03-04-2012, 08:35 AM
shiftmx's Avatar
shiftmx
shiftmx is offline
6th Gear
I just have a push button starter switch on my sporty bobber right where the key used to be. If they want it that bad they can have it i suppose. They better hope i dont find them later though.
Old 03-04-2012, 08:43 AM
pococj's Avatar
pococj
pococj is offline
Received 1,297 Likes on 484 Posts
Haven't used a key for a very long time. Push buttons and toggle switches, and a suicide clutch & hand shift for theft deterrent, LOL.
Old 03-04-2012, 08:51 AM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
To hotwire the 04's and up, you just need to splice all 3 ignition wires together.
Old 03-04-2012, 10:35 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
Locks are just to keep the honest people out. If someone wants it that bad, they will take it no matter what. Although most theives won't put a whole lot of effort into taking something.
Old 03-04-2012, 11:44 AM
RacingJake's Avatar
RacingJake
RacingJake is offline
Since I have 5 degree cups on my 01 and cut the front fork lock off, I just use master locks on the front and rear brake rotors.
Old 03-04-2012, 12:02 PM
VirgeB's Avatar
VirgeB
VirgeB is offline
That is the truth. Had an 03 Honda 954RR sitting in front an apartment. Had it cable locked to the front wheel of another bike and a disk lock on each front rotor. They cut the cable, pulled the ignition plug, and removed all the bolts from the rotor to by pass the locks. Luckly they didn't get the bike.
Old 03-04-2012, 12:04 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
I'll just leave this here.
Guys Steal Motorcycle
Quick Reply: Good Lord these older Sportys must be easy to steal! Replace lock switch?
