Speedo problems
Speedo problems
I been having the suspicion that my speedo wire isn't getting a good connection, a wire is getting pinched or something with the speed sensor. I think it'd be the first 2 most likely. It's happened 2x now since doing the tank lift that the speedo has cut out on the highway and shown 0 mph. It also produces a check engine light that goes away as soon as the speedo comes back.
I'm going to pull the tank off tomorrow and check it out, die electric grease it again and make sure lines aren't getting pinched. Is there anything else I should look into?
Received 4,244 Likes
Check all the connectors...here is a link to a diagram that may be useful-
http://partsfinder.onlinemicrofiche....dmc&A=657&B=45
