Widest back tire without mods?
Help us to help you! What year bike, current wheel and tyre size?
If you have a 3" wide stock rim the widest tyre you can fit to it is 150/80, which has the same rolling diameter of an MT. However you need around 1/2" clearance between your current tyre and the belt to get one in. You can check that yourself!
We've covered this on another recent thread. The limiting things are clearance in your fender, plus clearance with the drive belt.
The widest tyre a 3" rim will take is 150/80, so for wider tyres a wider rim is necessary. If you have enough room, I am tempted to suggest trying a Deuce rear wheel, which is 4.25" x 17" and takes a 160 or 170 wide tyre!
