HD Turn Signal Mirrors
I've been wanting these mirrors since the day I saw them. I think they look really cool and they are definitely an attention getter (which doesn't exactly hurt when youre riding). I ordered them today, in black.
I just wanted everyone else's input on these. Does anyone else have them on their ride or something similiar? I haven't seen any on this site yet but I'm sure I'm just not looking hard enough.
What do you all think?
Missexeccph (11-27-2016)
However, and I'm an example. The sportster will "learn" your turn signals. For instance I don't have mine hooked up in the front, and the blinkers went really fast during my first 5 minutes on the bike to indicate I had blinkers out. Then it went back to a normal speed.
But I don't know if it's the same on your bike. Worst thing you have fast blinking signals or you need to get a modulator or whatever its called.
Schwingding, doesnt the Vrod come with the mirrors that have the signal in the actual stem of the mirror?
As far as how visible they are during the day, Im not too concerned with that because I often use hand signals anyways.
The current turn signals are some what blocked because of my Quarter Fairing, so they only show about half as you can see in the picture.
You can find them at http://chromeglow.com in the mirrors section. Be warned though, there are no instructions so you'll have to fiddle with them to determine which leads are which as they have a brake light function as well (which is really cool, btw). The red brake LEDs are invisible in the mirror's surface until activated. Sadly I cannot recall from memory which wire is which.
I should have written an instruction manual for these things because the brake lamp feeds back into the turn signals and shorts out the HD turn signal circuit. The way I rectified this was to install a $0.60 radio shack diode in the brake feed and in the turn signal feeds. A diode will allow current to flow in only one direction. Once I had this all hammered out everything worked fine, you can buy a bag of low voltage diodes at radio shack for about three bucks.
If you only want to run them as run/turns and forego the brake function you won't have any of these wiring issues.
