Key hard to remove.
Old 02-27-2012, 04:08 PM
Jackal's Avatar
Jackal
Jackal is offline
Default Key hard to remove.
My key seems to be getting harder and harder to remove from the ignition. Anyone have this issue before? I only have 1 key to try...need to have another one cut I guess.
Old 02-27-2012, 04:12 PM
Aaron48's Avatar
Aaron48
Aaron48 is offline
Mine will do this once and a while. I'll put it in and it kinda sticks as it comes out. No big deal so far.
Old 02-27-2012, 04:18 PM
GlidingFree's Avatar
GlidingFree
GlidingFree is offline
A little bit of graphite lock lubricant should solve the problem.
Old 02-27-2012, 04:19 PM
hincheec's Avatar
hincheec
hincheec is offline
add a little lubricant to the key. mine used to stick. now it doesnt.
Old 02-27-2012, 04:20 PM
jeffreydsilver's Avatar
jeffreydsilver
jeffreydsilver is offline
Default Part Of Regular Maintenance
Go to your local auto parts store and get some lock cylinder lubricant. Use it once or twice a season as regular maintenance.
Old 02-27-2012, 04:24 PM
HERE's Avatar
HERE
HERE is offline
Is your key relocated between the cylinder? I've heard of instances where the vibration causes the tumbler in the ignition to take a dump and could end up with the key stuck in the ignition. I know of a guy here locally who has had his key in his ignition for atleast 6 months because of this.
Old 02-27-2012, 04:33 PM
Jackal's Avatar
Jackal
Jackal is offline
I relocated it behind the rear cylinder and wondered if this wasn't the cause. I'll keep an eye on it and might try some key lube of some sort.
Old 02-27-2012, 06:19 PM
VirgeB's Avatar
VirgeB
VirgeB is offline
Make sure it is a graphite and not a spray (liquid) lube. This only attracts more dirt and will make it even worse.
Old 02-27-2012, 06:38 PM
Jackal's Avatar
Jackal
Jackal is offline
I used G96 for now and that did the trick! I used it because that is what I have always used in stick old locks and my trucks and have never used enough to worry about attracting debris. Then again I should probably do them more often like this. Mostly everything but the silicone evaps anyway. I went ahead and ordered me a new Willie G. key too. $60 for a f#king key...who pays these damn prices? Oh wait...
Old 02-27-2012, 07:29 PM
Superfly3176's Avatar
Superfly3176
Superfly3176 is offline
I was gonna say then I saw the Oh wait. There's somethings from harley I will buy, but others like the key I won't. But hell I bought like a $40 gas cap.
Quick Reply: Key hard to remove.
