Ok, looks like I fried something!!
Read on here from some guy that he washes his Sporty with the seat off. I'm tired of having wet pants after I wash my bike so I decide to wash my bike with the seat off. I'd be much better off with wet pants right now!!
Apparently Harley engineers, in all their wisdom, decided not to make the elect. connections under the seat, or anywhere for that matter, water proof. Or so it seems or maybe I've just got pissy pants, I don't know. I got up yesterday morning to start my bike and nothing. Not just nothing but NOTHING! No speedo light no nothing!
So I take the battery out and put it on my trickle charger and leave it there overnight. Thankfully little to no damage was done (hopefully) because it came all the way back up to a full charge. I put it back in my bike and I notice the little red key on the lower right of the speedo, the one that blinks if you have a factory security system, is lit constantly. No blinking and no going off. I'm thinking "this aint' good"! And it wasn't.
I followed the diagnostic code process and came up with the following: b1141, ignition switch low/open and b1005, fuel sending unit high/open instruments.
What do those mean? low/open? high/open instruments? I don't get it.
HELP!!
PS: The bike started after I put the batt. back in but when I put the key in and turn the off/run switch to run I don't here the fuel pump whirring and the low fuel light stays on with a full tank. It starts but I'm afraid if it sits and the pressure goes down and the fuel pump isn't coming on before the first start, it may not start. It ain't right.
HELP!!
Well, it's been a little over an hour since I started this thread and I've figured it out. And thanks for the advice about using a trash can liner, I think I'll do that in the future.
It was the relays again. Again? Yep, it was the same thing that gave both me and two, count them, two Harley dealerships fits trying to figure it out. They never did figure it out, I did by accident.
I was about 50mi. from home on an early Spring ride and when I came out of the store I had been in for about 1/2 hour and my bike wouldn't start. It wouldn't turn over at all. The lights came on but that's it. I start pullin fuses and such because when the Sun goes down I'm gonna freeze before I get home on the 50mi. ride!! I just happen to accidentally switch the two identical relays, one for ignition and one for "system" and the bike turns over but won't run. I call the local Hardly dealer, right at quitten time btw, and one of the guys, a real life saver btw, drops two off on his way home to me. Varooom! and away!
So today, because I'm simply stumped, I do the same thing, start pullin fuses and stuff. When I pull the first relay I remembered the story above and decide to switch the relays and see what happens. Varooom! and away! Not really as it's too cold to ride right now but you get the picture. The water got into the area where the relays plug into and shorted them out or caused a break in one of the circuits and it was all messed up. I won't go in to detail about all that the bike was doing because, honestly, I can't keep track of all the strange crap my bike was doing. It has a factory security system (useless if you ask me, flashing lights? Wow that'll stop 'em) so you can imagine all the weird shenanigans that thing was pulling! Anyway, it's over. For now! It's still a Harley.
I really hate(yeah right!) Harleys!!
OMG, this was a serious post? When I first read this, I thought it was somebody that was just bored and started a funny post. Yeah, there is a reason all of the computer modules, and other sensitive electronic components are crammed into the small space under the seat. The reason.......SO THEY DON'T GET WET.
Had you posted in the OP that you have an 07, I'm sure you would have received several answers telling you to pull and clean/dry the fuse and relay contacts. Water intrusion is a common problem with that bike.
