Running Lights
Yes, you'll need new three wire turn signals for the rear. With the new signals, run the purple and black, if I remember correctly, as they were with the original stock signals, and then run the blue wires to the brake light housing. There's a spot already open in the wire plug housing of the brake light assembly that you can tap the blue wire into. I spliced both blue wires together for one pin connection into the assembly. Oh, and I went with the smaller bullet style, like on the newer models sporties, turn signals front and rear.
