Years for 1200s
Old 02-07-2012, 12:08 PM
swordy's Avatar
swordy
swordy is offline
Big Kahuna HDF Member
i have a 1200s 2000 model twin spark (2per head)etc its light years beta than a standard 1200
Old 02-07-2012, 12:37 PM
Raider Dana's Avatar
Raider Dana
Raider Dana is offline
I bought the Service Manual for my bike, and the more I read, and more I tinker with it, the more cool stuff I discover this model has.
Old 02-07-2012, 03:07 PM
Robotech's Avatar
Robotech
Robotech is offline
The 1200S has a whole different ignition system than a standard 1200. It has twin plugs because it has higher compression than does a standard 1200. The heads in the 1200S had much smaller chambers to achieve this higher compression using the same 1200 pistons. It was found that some of the air/fuel mixture could be "shadowed" from the spark of a one plug design so Harley added the second plug to overcome this issue.
Later Harely, via Buell, went to the Thunderstorm piston/head combo because keeping the chambers larger while reducing compression with a domed piston was the better way to achieve the same results and eleminate the need for two plugs.
The 1200S was also the first Sportster to come stock with the W-grind cams. These cams later were introduced into the standard 1200 line (2004) and then the entire Sportster lineup (2007).
BgDadddy
06-11-2023 04:58 PM
longwalkhome
04-17-2008 01:38 AM
thomasf59
10-23-2007 05:07 PM
Delrob
07-18-2006 05:22 PM
Thumper26
05-11-2005 09:21 PM
Quick Reply: Years for 1200s
