Don't waste your money on that POS. Use that money and add alittle more and get something that works. I use Cobra FI2000 powrpro now after replacing my fuelpak. I am happy now...... AGAIN don' waste your money on fuelpack
Agreed, after all I have heard about the FI2000 its a no brainer.
To answer your question though, you should be able to wait until you replace your AC until you need air/fuel adjustments.
I have the VH FP na it works perfect. It is not a tuning tool so you need to find out if they have settings for that exhaust with the High flow AC. The FuelPak does the trick if you do not plan to upgrade the motor and they have the settings for your set up, if you do ANYTHING custom it is not the system for you.
you can run the exhaust and a/c with no other modifications and no problems. How am I so sure? because i have that exhaust and a performance machine intake and nothing else and my bike runs better than ever. Been running this way for about a year and a half, about 7k miles, everythings fine.
fuel pack works good for managing your fuel if you have no future plans for engine mods or top performance. if you want the performance get a good tuner and have it dyno'd..... i've heard good things about the cobra units.
Look up xieds or got to nightrider.com. I have them along with a lot of other people and it works perfect. Saves you a lot of money also since they are only like 100.
I'm either getting the PowerVision or the SEPST for tuning the bike. This year, I will start out small with the AC and the Bobcat exhaust. I'll get it dyno tuned. At the end of the year, if I still have the itch, and probably will, I'll change the cams, head and displacement to a 1250. I'll have the foundation to build on. Something I don't believe the fuelpak or the cobra or the Xieds will do.
I have used the Power Commander in the past with great success on other bikes. It has a full range of tuning ability including fuel maps and timing. If I was going to do major mods I would go with the PC.
