Yes, another exhaust thread
So i got my sikpipe diesels put on my 48 yesterday. First of all, my god they are loud. I had read that they were loud but they exceed what i thought loud was. Anyway, I took it out for about a 5 mile ride and realized when i got home that the pipes had gotten so hot that they melted the air cleaner plastic cover. Also, i have thermotec copper wrap on them with a copper spray coating and both pipes had turned blackish presumably from the heat. My plan was to get them on with the stock air cleaner and see if it sounded rich or lean. Sounded great so i figured i was in the clear. But, since they melted my cleaner cover i guess i am now going to get a new cleaner and will have to get it tuned. Tyler at sikpipes thinks the pipes are getting hot because i dont have a tuner and the motor is running lean. Does this sound like the likely cause? like i said, there is no popping on decel and it sounds perfect.
I have the diesels and like you only took it out for a couple miles. When I first started it in my basement garage (little dark) I could see flames coming out the rear pipe That went away after it warmed up though. I was suprised I had NO decel popping. I do have VIEDs but didnt adjust them from when I had the short shots on. And loud? F yeah their loud. I couldnt stop grinning. Dont know about your heat issue......sorry.
Shorty pipes will always be hot and loud. I have shorty pipes with no baffles and they are way hot every time I ride. Definately get a tuner. I have the PC-V on mine and it helped out to make the bike run better. I would recommend getting it to a dyno shop and have it more fine tuned also. That's on my "to do" list this year. The pipes look sweet on your bike!
Oh great now everyone is going to have sikpipes on their bikes instead of black short shots haha. I'm glad I got the double barrels because the diesel's were a close second in choice. But yeah it sounds like you're running lean and that's causing the heat issue. You can try xied's or a tuner, dunno if that's going to help you though since the pipes are short to begin with.
There is a thread on here somewhere talking about how modding pipes and AC doesn't require a tuner or anything else. They say it's a myth and if you just do pipes and your AC that's perfectly fine without further mods. However, just from your pics, I have come to this conclusion....
1. In a lot of custom exhaust applications it was say in writing "may not work with stock AC". I bet anyone running sikpipes for the most part has a smaller aftermarket AC. On my bike, I don't even know if my sikpipes would clear the stock AC. So think about that for a moment with your melting issue.
2. Your wrap has discolored where the pipes always are the hottest. When mine were chrome, they turned blue/gold in those same spots. When I wrapped them, the black wrap turned gray/white in the same spots as yours have turned a dull black.
From your pics, I think IMO that you do not require a tune and that either your wrap is cheap and failed or the coating was cheap and burned off causing your wrap to discolor.
I know your not gonna want to wear shorts while riding with those pipes. I did one time with my fuelies and made it about 10 miles and had to turn around and put long pants on. Burnt my leg big time from all the heat! Plus no one is gonna ride next to ya! Loud is good, beware of the cops! I've been pulled over twice so far for being too loud! Just got warnings though because they didn't have decibal meters on them. Those handle bars are awesome! Are they brass?
