DIY throttle lock?
Old 01-24-2012, 07:08 AM
Shackleford's Avatar
Shackleford
Shackleford is offline
Originally Posted by Certainteed
in the way-back days there was no government mandate for spring-return throttls. people rode for decades without them. the tensioning nut is there for your comfort and doesn't cost a thing. set the tension so the throttle stays put and adapt to closing it manually. you'll acclimate pretty quick.
Wow, no spring return on the throttle! I can't even imagine what that must have felt like.
Old 01-24-2012, 07:09 AM
Shackleford
Originally Posted by BiggDogg
for some reason when I throttle lock, my air cleaner bleeds oil out of the filter. So I don't throttle lock anymore. Tired of oil on my crotch
That doesn't sound healthy...
Old 01-24-2012, 11:08 AM
cuda67bnl's Avatar
cuda67bnl
cuda67bnl is offline
Had a 69 sporty like that when I was about 18...... Took me longer to get used to the brake and shifter being on the wrong sides than the throttle not snapping back..........
Old 01-24-2012, 11:12 AM
cuda67bnl's Avatar
cuda67bnl
That makes no sense...... It would be no different than you holding the throttle in the same position. Unless I'm missing something.........
Old 01-24-2012, 12:05 PM
BiggDogg's Avatar
BiggDogg
BiggDogg is offline
What I later found out was that the bolts needed to be tightened up again. But I still never went back to the throttle lock
Old 01-24-2012, 12:20 PM
TexFF's Avatar
TexFF
TexFF is offline
So is that star wheel DESIGNED to be used as a cruise control or is it's real purpose something else? I've always wondered why the hell it's there.
Old 01-24-2012, 12:32 PM
Jackal's Avatar
Jackal
Jackal is offline
It works perfectly as a set it and forget it adjustment / cruise control with the light as hell stock rubber grips.
Old 01-24-2012, 12:57 PM
Shackleford
Mine doesn't. I have all kinds of complaints about it.
Old 01-24-2012, 01:23 PM
Jackal's Avatar
Jackal
Jackal is offline
I think that's it's intended purpose anyway, and worked perfectly on my 08 N till grip swap.
Old 01-24-2012, 02:26 PM
TRacer's Avatar
TRacer
TRacer is offline
Originally Posted by X04D
Take the star lock off, find something at a hardware store that will fit the hole, weld a piece of metal to the end of it, re-attach.
Not welded, but close. Cost: free from my Drawer o' Loose Nuts & Bolts.
Quick Reply: DIY throttle lock?
