D2moto Taillight
I have yet to figure out the blinkers...
I didnt know you had to. The running light and brake light work fine. I figured if they were going to sell the entire module they would sell everything needed along with it. Nothing on their website says you need anything additional and the box it comes in doesnt say anything.
I might as well share my experience...Shipment was quick with them but they sent it in a padded manilla envelope and the package was pretty mangled. I also ordered their smoked signal covers and again the manilla envelope was mangled up, one of the covers were cracked. I emailed them yesterday, we will see what they will do.
My package was in good shape when arrived. Come on, someone helps me to figure out how to pins from the turn signal connector!
Take a look at this site, it shows how to take pins out.... I've read some posts where the turn signal wires were cut and spliced back together.
http://99mpg.com/mima/pininstall/ins...ingtheharness/
As far as the module, I did not use one and the turn signals work fine. There are other threads on the site about the tail light, try a search. Sorry I couldn't help more, but it went together and worked ok.
No, the connectors on that site are different, but was thinking the pins should come out in a similar fashion. I used a pick tool and it released the pins quickly, just like the site shows. Maybe your plugs are different than my Dyna.
Anyone using this?
http://www.d2moto.com/p-6845-harley-...LAID=544012648
I need to replace my Kuryakyn L.E.D. taillight and find a solution to get rid of my turn signals to clean up the rear end. That seams to be an affordable solution.
What do you guys think?
Thanks!
Thanks!
