Need stock length cables
Ok, I took some pictures of the cables.
The throttle cables I'm not worried about.
The brake line is one piece and just seems to have a bolt at each end. Is it as easy as removing the line and bolting on the new one?
The clutch cable is my biggest worry.
I see a type of connector midway down the cable. The little rubber boot used to be here. When I get the stock cables can I just unscrew this connection and attach the new piece or does the whole cable need to be replaced at the engine?
Please help!!
Please help!!
If you don't have one, get one and save yourself a lot of headaches and money in the long run.
If you don't have the tools to do the job properly, that includes the SM, take the bike to someone that does. You do want your brakes to work correctly, right?
