Exhaust and Power and Sound
Stuck in sort of a bind and in need of some advice.
I'm a proud owner of a 2012 Iron 883 with a 1200cc conversion, SE Heavy Breather, SE pipes, SE Slip-ons, Stage 1 DL. The runs good and my only qualm with it was the sound of the exhaust. It definitely sounded great at a cold start up, but after riding for about 20 minutes or so I am not fond of the sound of my pipes. I wish they still had the roar and rumble it did at start up.
So, of course I recently picked up a set of custom pipes that I fell in love with. However, I have now realized that I lost a significant amount of Torque and HP. A typical road I take on my way home, if I "ride it like I stole it" I was able to easily hit 90+.
My question here is, is it just the pipes? or is it because I need to tune and Dyno the bike because my ECM was initially set for my previous set-up, therefore it doesn't run like it used to? Will I regain the Torque and HP I remember, if not better by doing so? Or does having louder pipes with shorter baffles take that toll?
Aside from the above, I am also not 100% happy with the sound. They are definitely louder! However I really wished they were less throaty and more deep. My girlfriend (who doesn't like loud anyways) said that the note doesnt sound smooth. I can definitely notice the sound difference but I cant hear the exhaust when I'm moving over 40mph. I remember when I wore my full-face I could hear a deep hum from the exhaust but now I dont hear anything. Why is this? Is there a way to make deeper tones?
Thanks in advance folks, ride safe!
Received 4,221 Likes
Typically louder and shorter pipes end up reducing the speed of the exhaust gas velocity, which will result in less torque, especially in the low & mid RPM range.
There is an inexpensive solution that will increase your Torque & horsepower AND equally important, it will give you the ability to fine tune your exhaust note...both in volume and tone.
Thunder Torque Inserts
Earlier this week we did 63 pulls on a dyno, 21 different configurations, 3 pulls per config.
Today I printed up the charts and we should have a bunch of them posted in this next week with notes.
One of the charts we will be posting shows two pulls
1. Stock 883 with stock pipes drilled out
2. Stock 883 with stock pipes drilled out with Thunder Torque inserts
Results: 8%-20% increase in torque between 2000 and 4500 RPM. Horsepower which really does not mean much, but everyone seems interested in, was 5%-15% higher across the rpm band.
Here's a couple of videos
http://www.youtube.com/watch?v=yWenm0J9Jug
http://www.youtube.com/watch?v=eNGKgB0-f5A
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
More information is needed to make an informed decision. Does the exhaust have a baffle? What is the diameter of the tubing? What is the length of the tubing (approximately)? As far as sound that is a very subjective matter and typically to achieve a particular sound you are going to compromise power output in some way or vise-versa.
DK - My pipes have a 1 7/8'' inside diameter will the TTI fit? I see 2'' and bigger on the website.
Ian - The pipes do have a baffle, tubing diameter is 1 7/8'' inside.
So, despite sound, if I tune and dyno the bike will i regain my HP or Torque if not more? Will that make a difference?
You will want the 118 Models. They will be on the website later today.
With a dyno tune you may regain some of your Torque, but not all of it, the physics of your shorter pipes simply increase the engine pumping loss. That is what the Thunder Torques are for, is to reduce the engine pumping loss, resulting in increase Torque & HP.
Check out post #74 at this link-
https://www.hdforums.com/forum/sport...83-iron-8.html
Fortunately for me, I have no appreciation for sound or aesthetics so I can simply choose max power which is quantifiable and not have to have compromises except with the wallet.
Dan,
Charts are being scanned tomorrow and should be up in the next few days.
Yes, they install like lollipops...in fact, they are just very fancy lollipops... because of the shape and materials used, they generate much better results than lollipops.
btw, the 118's are now up on the site- HERE
