Engine Oil Preferences???
I use Mobile 1 for V-Twin which is also suitable for the primary (=wet-clutches, doesn't have the anti-friction additives that regular automotive oil does). Notwithstanding what was mentioned about oil filters, I would go with the original Harley oil filter as it is a 30-micron pore size which is made for a Sporty. The finer pore filters may clog and trip the by pass and you will have defeated the purpose of having a filter.
http://www.gopurepower.com/store/ite...em&itemKey=684
Whatever you do, stay away from the so called 5 micron filter. The Sporty oiling system is speced at 12-15 psi. It's a flow based system instead of a pressure based system like the TC's. Most filter bypass valves don't open till 8 psi to begin with so it's very important that your filter flows good. If you don't mind spending the money, these are very high flow filters. I have one on my 06XL, and 08FXSTC. And according to Blackstone Labs, who does my UOA's, they filter extremely well. Prior to installing one on my 08 96ci. oil pressure at idle, engine hot was around 6 psi. After installation it jumped to 20 psi due to the increased flow throughout the system.
I dont think I understand. I dont know a hell of a lot about these engines and their oil systems and pumps but make my living using pressure washer pumps. I would think the physics are the same. You can increase pressure one of 2 ways, increase flow from the source (oil pump) or restrict flow downstream of the source. You said your idle pressure increased almost 3 fold just by changing the filter. How does it do that without restricting flow?
Do people really believe that vehicle manufactures make oil?
Do you know that HD's motor oil is made by........... CITGO?
Do people really believe that at about the same price, HD's Citgo oil compares with the likes of Mobil-1, Amsoil, Redline, etc?
You'd get more peace of mind, if you learned something about oil. There's an entire Oil Section here on the forum.
By increasing flow through the filter, it increases volume in the oil galleys throughout the motor. At idle through a restrictive filter the oil flow isn't sufficient enough to completly fill the galleys. Fill the galleys to capacity then you get your pressure increase.
Not trying to be argumentative, just trying to understand.
Im sorry, still doesnt make sense to me. According to my manual my bike has a gerotor pump which is a positive displacement pump. Positive displacement pumps pump a given amount of oil at a given rpm..............no matter what. So lets say (just pulling numbers out of my *** here) at 1000 rpm the pump produces 1 gal per minute of flow. If filter A is restrictive whether by design or a clog, the pressure will increase until the restriction is overcome, either through the filter media or a bypass. Either way, that 1 gpm is going to flow. If filter B is less restrictive it will need LESS pressure to overcome its resistance. This is exactly opposite of what your saying is happening with your bikes. Im also assuming that pressure is measured between the pump and filter, which it is on my bike, at least for the idiot light, I have no gauge.
