Clutch Inspection Cover Removal....WTF?!?!
UPDATE: Ok, I went through the toolbox and found I had a T-27 in a changeable nut driver tip. I found a 1/4" socket to fit that tip and went after it. It fit perfect and they all came out without a hitch. The new Joker Machine cover went on with the allen's provided and the Torx are now in the trash!!
Thanks everyone so much for the help. I love being able to ask questions here and get the answers quickly by people who have been there, done that. The service manual didn't even tell me the size, it just said remove.
Thanks again!!
Thanks again!!
Derby cover spring
What spring? Someone mentioned a spring behind the derby cover, and I just changed my derby cover with an HD live to ride gold, and didn't spot any spring. Normally I change my own oil but took it to the shop to swap all ois to syn3, so maybe they lost it???!?!?! Does an 09 XL883l even have one?
I've never encountered one in my years of wrenching on Harleys.
+1 on everything already said. I've had to drill the heads off of those screws before. Not really a big deal other than being ticked off I had to do it. If you do have to drill them off use a drill bit about half the diameter of the head of the screw. A new set of screws at the Harley dealership is cheap unless you get the chrome ones. And, they're one of the few parts my local dealership actually keeps in stock.
As someone pointed out, make sure you have a good quality T-27 tool. I actually bent the splines on a cheap tool on these very screws. And, bent the splines on the T-40 socket from the same set (which is now in the trash).
Simply untrue. There are no Torx Plus on these bikes. I work on my bike with a $15 torx set from any big store.
