2009 Sportster Battery drain
Good afternoon,
I have a 2009 Nightster and I am having an issue with the battery. The original battery lasted 2 1/2 years, I replaced it w/ an Interstate battery and I have been having problems ever since. The battery is draining too quickly and I am not sure what the problem is? I have had replace the battery 3 times in the last yr.
I finally bought a battery tender but I have not hooked it up since I just ordered it.
Any ideas what could be causing the battery to drain so quickly?
Thanks,
Floyd
Thanks,
Floyd
could be a relay not closing. could be security - if you have it. could be connections not tight. could be alternator / regulator related. get an amp meter and use it on your fuses to see what if any are drawing current and your regulator to see if it is working properly. Battery Tender + always use it even in warm season. if you don't have an service manual look on line (ebay) and pick one up. they are worth the $ and cheap. good luck. ride safe and often.
Don't mean to hijack but i got the same problem w/my 07 1200L so maybe my question will help KC also. Tried the above and yes I have a short. My battery drains fast and the tender doesn't help. got power but not enough to crank. when I hook up the hot cable it's good but when I hook up the other cable with the main fuse on it there's a spark. any idea's?
Down South
05-01-2018 03:46 PM
