Cheap easy stash tube.
Old 01-01-2012 | 04:55 PM
dmooth's Avatar
dmooth
Originally Posted by Gpsjr10
Looks like alot of work to remove the items inside. Maybe you could solder brass nuts to the inside of the caps then use thumb screw bolts to remove it from the L brackets eaisily. (Maybe solder one of the caps on too) That way your threaded rod isn't taking up most of the room inside the tube.
Took your advice and soldered the nuts the the inside of the caps. Had to trim the ears on the thumb screws a little, but it works fine. Looking for some brass thumb screws. Thanks....
Old 01-01-2012 | 06:32 PM
Gpsjr10's Avatar
Gpsjr10
I was imagining something more like this. I would think Home Depot would carry something like this.
Old 01-02-2012 | 12:06 AM
dmooth's Avatar
dmooth
Yep, I had forgotten about that type of thumb screw until I started doing the google search, I'm on the hunt in the morning for that type of thumbscrew, should work perfectly.
Old 01-02-2012 | 12:28 AM
2black1s's Avatar
2black1s
While your out, grab a spray can of clear coat to keep it looking nice without the need to be polishing it periodically.
Old 01-16-2012 | 08:55 AM
Bigfoot1's Avatar
Bigfoot1
Did mine a bit different, wing nut on the left. When you loosen a bit and relieve the pressure the cap slides right off. It's as waterproof as it needs to be. Thanks for the idea.
Old 01-16-2012 | 09:50 PM
Mr.Twisted's Avatar
Mr.Twisted
Looks good! what did you use to mount it to the tag? Looks like the OP used some small "L" brackets..
Old 01-17-2012 | 12:53 PM
Bigfoot1's Avatar
Bigfoot1
I was at the local aftermarket shop and found a pair of "b" brackets, kind of like a wire loom clamp. They had no part # on the package but were Custom Chrome and hanging in the exhaust section. Fit the caps perfect.
Old 01-17-2012 | 01:07 PM
Bigfoot1's Avatar
Bigfoot1
Old 02-28-2012 | 02:26 AM
DOMAPOI's Avatar
DOMAPOI
In the movie Easy Rider, he just used a big vinyl hose with a couple of corks and stuff his stash in the tank tube. Just saying.
Old 02-28-2012 | 06:19 AM
WVleo's Avatar
WVleo
Very nice and very practical, but if it Ain't chrome it's not going on My bike LOL LOL ! Plus I keep that stuff in My wallet. Good idea swap all around tho....ride smart, ride safe........wvleo
Quick Reply: Cheap easy stash tube.
