Oil Change Q
Old 12-25-2011, 07:37 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,744 Likes on 3,968 Posts
Originally Posted by 2black1s
Here's what I did to eliminate any excess oil in the air cleaner (see pics). Not a Sportster, but same principle anyway. I never had enough oil to actually leak out of the air cleaner, but whenever I took the air cleaner element off I could see a little oil puddled in the bottom. I did this breather tube mod to the backing plate of my SE air cleaner and my air cleaner element is dry as a bone since.
Couple thoughts on this. From previous years of v-twins I have never had one that does not throw a little oil in the filter especially at high rpm. Most just collect and is easily wiped out. Some gets on filter which probably helps collect dirt. Mine drips a few drips on lifter cover if I let it set a few weeks and then drive it hard. (oil tends to run down and collect when bike is left setting) Had an 05 few years back that had a drain hose on the bottom of the box. I really think Harley only intended for the actual mist to be drawn into the engine. Putting the actually pipes back into the throttle body probably is not a real good thing since oil does not really burn in a liquid form until it get on the hot exhaust valve and stem area. Just a thought for thinking and of course debating. Not trying to steal thoner7's post...
Old 12-25-2011, 04:13 PM
DENGUY's Avatar
DENGUY
DENGUY is offline
I had oil dripping out of my AC and dribbling down the side of the motor and pooling on top of the side cover and blowing backward on everything all the time. It finally stopped when I let the oil level drop to anywhere between the bottom mark on the DS or about 1/4" below it and kept it there. I also put on one of those finned aluminum permanent oil filters which is supposed to draw off some heat from the oil to compensate for the slightly lower oil level in the tank.
Old 12-26-2011, 05:54 PM
hogsport's Avatar
hogsport
hogsport is offline
Pretty much like CHarley and others, 2.5qt brings my '05 1200C to halfway between fill and full marks. The manual says anything over the fill line is fine. Mine uses / pukes no oil & hasn't in 31k miles.
Twisted Humor
09-23-2022 01:31 PM
MNtadpole
11-09-2015 07:42 PM
Dancemax
Oil Archive (no new posts)
08-06-2007 07:23 AM
Mad Dawg
07-11-2007 06:45 PM
Buda
05-16-2007 12:30 PM
Quick Reply: Oil Change Q
