Ok Swingarm Bushing
Ok Swingarm Bearing
Alright damnit out of everything I am buying for this, this seems the be impossible to find.
This is basically the most i can find. Swing arm bolt kits.
http://www.debrix.com/Swing-Arm-Bear...44-0540-vt.htm
Is it just a MUST to do the bolt and stuff with it?
you could get the bearings separate at any bearing supply house, there is a number printed on the bearing that matches up with the new one.. a lot of times they can match up bushings too.. have you tried the dealer.. a lot of times on small parts like that,the dealer is the cheapest you can find it.. i have bought tons of oem shovel/ironhead parts at a dealer for a third of the cost of aftermarket.
