Do my dyno numbers seem inflated?
All dyno's are going to be a little different on their readings. The climate also has some play in how the bike tunes. The guy that tuned my bike said he prefers tuning in the middle of the summer because the bikes seem to run better all year round. Since it was a little cooler outside when he tuned mine he said I may have some small issues when it gets hotter outside.
I would question the accuracy of that dyno, you are around 10HP higher than you should be. If that tech thinks he's really getting those numbers, I would go somewhere else. And if he told you he could get those numbers with just a Stage 1, someone is manipulating the dyno, or there is something wrong with it.
Dyno results will vary from machine to machine and even vary on the same machine a little bit because of variances in testing conditions, but there's no way it should be that far off.
I don't like dealers that give a jacked up dyno chart to make you feel like you got your money's worth, (our local dealer does this also) if you want to really know what it's doing take it to an indy and have it repulled.
