Lowering blocks + rough road =
Old 12-17-2011, 09:39 PM
VirgeB's Avatar
VirgeB
VirgeB is offline
Angry Lowering blocks + rough road =
Good thing I got over a 100 mile ride in today before this happened. Well, now I need to get a different type of lowering block. This will only be a quick fix until I can save money for shorter shocks. I have my brake light and plate located on the left side of the bike. I guess when this happened it also caused the filaments in the brake light bulb to brake. Also the left turn signal/running light is not working. I swapped the bulb to the other side and the bulb is good. Also have voltage at the light plug. At this point I'm hoping that some how the brake light and left running light are tied together and when I replace the bulb everything will be fine. Guess I have to wait until tomorrow before I can figure that out. Off to ebay to get new lowering links.
Old 12-17-2011, 09:45 PM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
Glad you're ok. Never skimp on the safety side of things. Ride safe, dude.
Old 12-17-2011, 10:00 PM
Voony's Avatar
Voony
Voony is offline
I'm sorry but what did brake? The picture is kind of confusing to me.
Old 12-17-2011, 10:06 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
The angle of the pic looks like it is from the top of the block. Which blocks are they? I don't recognize that one.
Old 12-17-2011, 10:26 PM
VirgeB's Avatar
VirgeB
VirgeB is offline
I'm not sure which blocks they are as they were on the bike when I bought it. Here is a picture of the good shock below. What broke was were the bottom of the shock bolts into the block on the back side of the swing arm. Going with a completely different type of block this time. They will be made out of 1/4" thick steel plate. Think these were cast.
Old 12-17-2011, 10:28 PM
RacingJake's Avatar
RacingJake
RacingJake is offline
I was going to say Hemmroids but that looks bad too.
They look like cast pieces ??
Old 12-17-2011, 10:33 PM
CrustySk8er's Avatar
CrustySk8er
CrustySk8er is offline
I ran lowering blocks for about a month. Save as fast as you can for the shorter shocks. The difference is worth it!
Old 12-18-2011, 02:15 AM
Stevieskull's Avatar
Stevieskull
Stevieskull is offline
lowring blocks are a joke. dont cheap out on lowering your bike
Old 12-18-2011, 08:55 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
For better stability, the ones that bolt on to the axle adjuster bolt may support it better, but I have seen those bend. I agree, the best thing to do is get shorter shocks. I put 12 inch Road Glide shocks on which are 1 inch longer than stock. I considered getting lowering blocks but I saw what happens to them over time and decided to go without, I ride my bike too hard to risk them breaking.
Old 12-18-2011, 09:24 AM
RacingJake's Avatar
RacingJake
Yeap I used one's from White Brothers, 1/4" steel that bolts to the swingarm and has a hole for the axle adjustment too. Worked great for years with no bending on my 01 Custom.
Took them off when I went the other direction with 13.5 shocks
Quick Reply: Lowering blocks + rough road =
