How to Install That?
Is this light smaller than stock? Looks undersize, but that's just my opinion. While I own and use a soldering iron all the time, I don't solder any DC electrical connections. I ALWAYS use heat shrink butt connectors and never consider electrical tape to be good enough to insulate bare wires.
Thanks, Ergo! Tho, I realized this morning that I have to trim the bracket. As it stands now, the bracket is too long and prevent me from turning the handlebars lol. I was very disappointed this morning...
I have yet to understand how to make the running light work since the headlight came with 2 extra wires for it.
It is way smaller than stock. It's 3.5" OD, while my stock headlight was 7". I think that I'm going to use heat shrink butt connectors too. I wanted to make sure that I connected the wires properly before doing anything more permanent.
It's really simple when you think about it. 5 wires in headlight and 3 in the old one. The 3 in the old one is for low beam, high beam and ground. Same as with the new headlight. The extra 2 are for power and ground for the running light. You can hook it to the ground of the headlight and it shouldn't hurt. As to the running light power, where you want it to be hooked to depends on what you are trying to achieve. If you want to, you can hook it to a "hot on run wire" or you can wire it to a separate switch so you can turn it on at will. You didn't say what you wanted it for so I don't know how to advise you.
Is there a way I can identify what cable is for the low beam? My stock headlight had 4 cables, not 3. One of which was the ground. My new headlight has 5 wires: 3 for the high/low beam, and 2 for the running light. It doesn't have a specific ground wire for the high/low beam, if that makes sense.
