Looking for "Knuckle" replacement part
Early sportys had mid controls and the later ('02 on) forwards used a Heim style rod end. Your shifter lever looks to be aftermarket and if it were me, I'd take it to a weld shop as my first move.
If it breaks again you could replace the shifter lever and rod end with HD parts from the later sportys. Any good machine shop could then make a new shifter rod to mate the threads on your new and existing parts.
The shiftter lever's spline pattern on the '93 and the '02 should be the same since the shifter shaft they mate to is the same part number: 34015-91 HarleyDavidson SHIFTER SHAFT, XL
Use Ronnies microfiche and parts finder ~ http://partsfinder.onlinemicrofiche.....asp?make=hdmc ~ Move the parts to the cart and then make note of the HD part number.
armadilloarms
General Topics/Tech Tips
06-17-2018 04:09 AM
billversity
09-08-2013 08:08 PM
Lanaki
06-24-2013 08:03 PM
