Metric to Standard Tire Conversion
"can anyone tell me if a 250mm front tire is the same as an 80/90-21 front tire?"
In metric tire sizes, the first # is the section width in mm, the second # is the aspect ratio, and the thrid is the rim size.
80/90-21 - 80mm wide, height of tire is 90% of the seciton width, 21 inch rim.
To convert a metric tire size to standard, divide the seciton width in mm by 25.4, then multiply that # by the aspect ratio in % and that will give you your height of the tire from rim to tread, then obviously the rim size. If you want to know the overall diameter of the tire, take the height and multiply it by 2, then add the rim.
Converted to standard -
80/25.4 = 3.15 inches wide
3.15 x 90% = 2.84 inches tall (rim to tread)
21 inch rim
2.84 x2 = 5.68 + 21 = 26.68(this is the overall diameter of your tire)
A 250 mm tire is approximately 9.85 inches wide, or considered a 10 inch tire, the 80/90-21 is 3.15 inches wide.
21 inch rim
