08 Nightster front suspension advice.
I think I'm gonna go with the superbrace first and the intimidators, I dont bottom out a whole lot but in tight turns my handling seems poor..I went too ricors website I don't see the intimidators for 39 mm forks all I seem to see is 41, I know I have 39's on my bike like I said earlier I have had my bike for 2 years and I just started wrenching on it in the last 9 months or so still new to the mechanical side of it. But the manual is awesome.
Check the Ricor website again , they do have 39 mm intimidators and also buy the recommended fork oil ( Amzoil ) from them .
Ricor has been around for a while now and it's a quality product. Put them in my 04 Sportster 2 1/2 years ago and I quit making changes to the front forks . I tried progressive springs , different wt. fork oil , Race Tech emulators, SE fork brace - ---Took all that stuff off added Ricors, Done !
I also put them in my 09 Road King Classic last year . Tremendous difference .
Honestly it has been a couple years and I do not remember what their instructions were like. I just remember I didn't have any issues while doing it.
Once you remove the fork caps, spacer, washer and springs...drain the fork oil...then yes they drop right in. Not a very difficult install.
I don't know when they changed, but recent Harleys don't have drain screws, certainly my 2011 doesn't. I had the forks rebuilt with Racetech springs and emulators recently and the chap who did it said that under normal conditions it is not necessary to change fork oil very often, but there is a build-up of dirt inside them that doesn't come out when using a drain screw. It is his opinion that it is better to remove the forks and clean them inside, when changing oil.
I put the Ricors in last fall. I dont even think about the front end anymore, handles the rough road and no fork dive. My 2010 has drain plugs. I was surprised how dirty the fork oil was after a few thousand miles. Replaced it with the 5wt Amsoil as recommended. I didnt trim the spacer so it gave more preload on the stock springs. It was easy install except getting the fork caps back on. My recommendation is what a HD service guy gave me, have a socket extension bar and a palm ratchet. You have to push down hard while turning to get that first fork cap thread started. A palm ratchet would have been easier than the standard ratchet I used. Harley should install these on all their bikes. I rented an Electra Glide Classic last month on vacation. After all the front end dive I was wishing for my Sportster forks with the Ricors.
Depending on your handlebars you may have to remove them. Might be a good idea anyways as it gives you a clear path above the fork caps. I think I have a bunch of pictures and a write-up I did for a friend on how to remove the fork caps. That gets you most of the way there. If I find it I'll post it here.
