CrAzYoRaNgE M/C
#572
haha...cocked in it's hole. yesh i noticed that too. i straightened it twice and i see it's falling back in it's hole....cocked. you replied too quick....forgot the pics on the first go round.
#574
#577
If the switch continues to give you fits you could go to a pressure operated brake light switch like below. The 10mm x 1.25 pitch is the size you'd need. Basically just replaces the banjo bolt and works off the pressure from the master cylinder. I bought one of these to use on the set of stock controls that I'm chopping up.
http://www.motorcycle-superstore.com...ht-Switch.aspx
#578
#580
