CrAzYoRaNgE M/C
#513
You sure you didnt break the little contact button off on the switch housing? I had the same issue and my switch was not bad it just broke the part that sticks out... My fix was builing up a little JB weld on the part of the lever that contacts the switch and the problem was resolved...
Just some words of thought if you run into the same issue..
#515
#516
yup 8" didn't want to go any taller. 10 would have made me change cables and what not plus i like lower bars. had a set of gimps and i hated them on the hi-way. those bars look nice man. rene?
#517
yeah i noticed the little rubber boot is all chewed up. i didn't shim it either, didn't know i had to. i did hear something like that on older bikes or bikes without stock hd controls but didn't even consider it.
#518
I opted not to use Rene bc he is swamped and the less work I give him the faster I can mail him my tank.. I feel bad but it will work out in the end. Gave him a deposit a while ago to hold my place in line till he had a lot of the work done and he can hammer mine straight out...
Anyways i went with syndicate choppers (Carmine) over on CC
#520
Beautiful job man. Love the bars. That's a bitch about the brake light. I'm worried about the same thing when I go to hook up mine, having chopped the housings up and rewired everything. I didn't see the part in the manual about shimming the brake lever before removal until after I took everything apart. But I don't notice any damage to the switch or the boot so, who knows? Anyway, good luck with that problem. Great job overall. Thing looks killer.
