Progressive fork springs...Nightster install?
Any of you "N" guys done this? I opened my box and saw springs and what appeared to be 3" PVC spacers. I didn't notice any instructions or washers, but I was in a hurry. I'm wondering if Progressive alters oil quantity from what the factory service manual says. I also wonder how much of the provided spacer you guys used. I've read that some had to buy more PVC for 3.5" or more spacing. I am 6'2" 210 lb. and ride 2-up on occasion. I am going to run a 10wt. fork oil. Maybe I missed the washers that are suppose to ride on top of the spacer...but if not I will get some. How much of a bitch was it to reinstall the cap?
I emailed Progressive, but don't want to get caught up over the weekend with no support.
Hey... if you are planning on trying different fork oil weights... I recommend you get this:
http://www.ebay.com/itm/Chrome-39mm-...#ht_1407wt_689
that way you don't have to disassemble half of the front end just to change the oil...
change, doble, fork, forks, front, harley, install, installation, installing, nightster, progressive, replace, sportster, spring, springs
