front brakes
front brakes
while out for a ride about yesterday , it seemed i had to pull the brake back further towards me to get the same amount of stoping power I have had to use in the past . I would venture to say near half the distance to the bars to feel any resistance at all ..
I might mention at this point , not a mechanic by any stretch of the word
but would be nice to have an idea as to what would cause this
i suppose there could be several different things that could do this . but are there any more likely then the other
thanks
thanks
I guess you get another post count ...useless....
the OP has a problem with his brakes ..a couple of posts were to help him ,,,, this was not
thanks..
I did not even think to check the fluid till I was posting the question,, then figured might as well post it anyways and see what others think it could be. I doubt its the pads this happened to quickly .. and the bump thing,, well that makes no cence to me either ,, sorry . maybe if that got air in the line or something I guess maybe , I dont know
as for the bike year and model .. the one in my sig. 2002 883 xl stock
I worked on a Softail that had the same problem. You had to pull the brake lever about 3/4 of the way before it would get solid. You could almost hit the grip if you braked hard enough.
Turned out it was just the piston inside the master cylinder wearing out/getting stuck open. Replaced the piston assembly and it is solid from the moment you grab.
