primary cover gasket change
No RTV is needed.
I do like to use a spray-on gasket adhesive (I use Nashua 357 gasket adhesive) on one side of the gasket and then stick the gasket in place on the primary before installing the cover. I find it makes installation easier not having to fight with gasket and cover alignment at the same time. The gasket adhesive cleans off easily the next time you need to open the primary.
I don't have a clue where the 10 o-rings would go.
No RTV is needed.
+1 on the adhesive.
I didn't figure out that little trick until after the first time I did this procedure. And it's not necessary to replace that gasket every time you open up the primary. I have an old gasket in my extra parts pile. At least I think it was the old gasket. I couldn't tell the difference.
Oh, but I do recommend plenty of anti seize compound...Trust me, you will appreciate this advice.
