Installing 2-up seat
I've been thinking abut getting a 2-up seat, probably a Mustang, and was looking at how the seat attaches to the fender. My '96 1200c has a hole in the fender with a plastic plug in it, but there does not appear to be anything for a bolt to thread into.
Is there some aditional part I need in order to install a 2-up seat?
Remove the plug, and move the threaded part where you currently screw in the seat to the back hole. There is a plastic clip holding the threaded part on the fender. All you have to do is remove the plastic clip, the metal threaded part will drop. Pull a zip-tie through the metal threaded part and feed it under the fender into the back hole, and reattach the plastic clip.
Trust me, it is a lot easier than it sounds.
I finally got around to checking this, and I don't see a plastic clip holding the threaded part on - in fact, it looks like the threads are part of the fender.
Is the plastic clip on the underside of the fender? Does this require lifting the bike?
