Nightster Winter Makeover
Old 06-03-2012 | 10:52 AM
fortyeight5k's Avatar
fortyeight5k
6th Gear
I'm really looking forward to the update on what your bars look like. Edge of my seat.
  #732
Old 06-04-2012 | 07:26 AM
Ergonight's Avatar
Ergonight
Originally Posted by J3r3myC0x
lmao, how's the weather for you right now though. At work I saw that the DC area had some Tornado Warnings and you aren't that far away...
Nah man, DC is a long way south of us.
  #733
Old 06-04-2012 | 07:53 AM
Ergonight's Avatar
Ergonight
Question
Me to, fortyeight. We worked on em most of the day Saturday. Made some progress but it's slow going. Internal dummy lights, internal wiring, internal throttle and bar end signals and mirror, custom switches...all that stuff requires a lot of fancy engineering/modification and that all takes a lot of time.
Here's where we are. Drilled the ends of the grips and drilled out the hole in the bar end mirror to fit the signals.
Modified the internal throttle to accomodate the signals.
Still have to modify the clamps and levers but here's the left side mock up.
Right side is trickier due to the throttle, which isn't completed yet. Also, due to the 1 1/4" bars the stock master cylinder needed a lot of modification to fit right. That took some time. I'm still gonna chop a lot off both the right and left clamps and levers but the master cylinder fits now.
Working on running the wiring through the riser bolts...not easy. Grade 8 bolts are tough to drill through, even with all the right tools.
I also spent some time cleaning up the appearance of the wiring. Used the wire wrap that Midlife recommended. It wasn't easy due to all of the branches and brackets and such to work around. But it does look a lot better now.
  #734
Old 06-04-2012 | 11:59 AM
bmxatv's Avatar
bmxatv
^^^fvcken trick dude!
  #735
Old 06-04-2012 | 12:36 PM
FlatIron's Avatar
FlatIron
ERGO!!! You gotta finish already te anticipation is drivin me nuts! I wanna see this bad boy all done! You have done a great job and have inspired me a ton!
  #736
Old 06-04-2012 | 01:04 PM
Ergonight's Avatar
Ergonight
Thanks guys. I'm trying my *** off Omar. But this stuff is like a fine wine...it can't be rushed. Of course...I could just drink beer...
  #737
Old 06-09-2012 | 11:04 AM
IVthCrusade's Avatar
IVthCrusade
Ergo- you mentioned at the beginning of this build that you had some help with planning converting the front end to wide glide. Care to elaborate a little? I would really like to widen the front end of my 08 nightster and add a wider wheel (just like yours, except without the rake). Any tips, info on parts, where to buy, etc., would be appreciated.
And I apologize if you already did this in the thread. If so, just say so and I'll dig more.
  #738
Old 06-09-2012 | 11:09 AM
rickss69's Avatar
rickss69
Veteran: Marine Corp
Here you go... http://vulcanworks.net/store_4/produ...&cat=11&page=2
  #739
Old 06-09-2012 | 11:14 AM
FlatIron's Avatar
FlatIron
Originally Posted by rickss69
Be very careful dealing with Vulcan... Horrible horrible customer service... The guy dodged my calls and I had to call from a different number every time, after I reported him to better business beareau he callled me to curse me out and threaten to kick my ***. HORRIBLE BUSINESS!!
  #740
Old 06-09-2012 | 11:18 AM
IVthCrusade
So that's all-inclusive except for a wider wheel. Does anyone sell the same thing in black?
Quick Reply: Nightster Winter Makeover
