Nightster Winter Makeover
Old 01-09-2012 | 02:57 PM
Ergonight's Avatar
Ergonight
Ok, so I haven't been able to get to the shop in the last several days, but my son-in-law couldn't resist the temptation to get his hands dirty (I think he's almost as excited about this project as I am, much to his wife's/my daughter's consternation). We've been talking about the tank lately and how and where to mount it. We both loved mreed's idea of keeping the tank low instead of raising it up, but either way the stock tank mounts had to come off. So last night (allegedly sometime after 3am) he did the deed. Here are some pics of the tank without the mounts.
The rear mount is a solid piece that runs almost the entire length of the tank.
We haven't made a final decision on the mounting points...I haven't had a chance to discuss it in detail or face-to-face with him yet. I think we're going to modify the rear mount so the *** end sits lower on the frame and due to the increased rake of the steering head it will have to be shortened so the tank can sit back a bit. We also have to make accomodation for the tang on the stock seat (which slides under the rear tank mount) so that it can be mounted as normal for two up riding.
One of these days I'll get some time back in the shop. Frustrating...
  #242
Old 01-09-2012 | 03:35 PM
RaceFace's Avatar
RaceFace
Nice!! The lower tank line is going to look GREAT with that front raked like that!! I love it!!
  #243
Old 01-09-2012 | 04:59 PM
Ergonight's Avatar
Ergonight
Thanks Race. I think you're right.
  #244
Old 01-23-2012 | 01:57 PM
Ergonight's Avatar
Ergonight
Busy at home, busy at work. So far 2012 has allowed me very few hours in the shop. I'm starting to get worried that I'm not gonna be anywhere near complete by the time the weather breaks. That's really gonna **** me off...
But, I managed two hours today, which was just enough time to lay out the wiring harness and identify and mark all the wires, save one. There's a single wire with a long thin rubber boot at the front of the harness that terminates near the voltage regulator and I can't remember where that goes. I'll figure it out eventually. Other than that I got everything ID'd and labeled with blue masking tape. And I know some of you are saying to yourself..."Why the hell didn't he lable every wire and connector as he was disassembling it?" And that would be a very good question. I live and learn. Wasn't too hard to figure everything out though. Most, if not all of the connectors are unique, and I had marked some of them with some smallish ID marks. I just had to take my time and match them up.
As always, here are some pics.
The unidentified wire is the one hanging between the front wheel and the frame, if anyone knows off the top of their head?
Next step will be to start tearing the harness apart and determine where each one will go. Still planning on an internal run for most of the wires, but we'll see how it goes. I know it's not much progress. Hopefully, time will free itself up in the coming weeks and I'll have more to report.
  #245
Old 01-23-2012 | 02:09 PM
Jackal's Avatar
Jackal
Check the right side between the mid control and forward control mount location for the missing link. Isn't that like the neutral switch or something?
  #246
Old 01-23-2012 | 02:16 PM
Jackal's Avatar
Jackal
  #247
Old 01-23-2012 | 07:12 PM
Ergonight's Avatar
Ergonight
Ah ya, that's it. Thanks man.
  #248
Old 01-24-2012 | 04:25 PM
Rog48's Avatar
Rog48
Im a little confused. I got a set of Wilwood rotors, front and back are 11.5". The specs said it fit 2000 and up sportsters. Problem is my rear is 10.25". I looked up the specs on the nightster and it seems to be the same. I was wondering how you did it then I looked closer at your pic. You have the caliper but I dont see a rotor..........what gives?
  #249
Old 01-24-2012 | 07:05 PM
streetfighter06's Avatar
streetfighter06
I'm curious as to the rear fender. You cut a little off the back, now that ECM gaping hole is still there. I would have just bought a trailer fender at Tractor Supply. What are your plans for that hole?
  #250
Old 01-24-2012 | 07:30 PM
Ergonight's Avatar
Ergonight
Hmmm...the Wilwood rotors I got were both, front and rear, exactly the same size as my stock rotors. Both front and rear rotors on the Nightster are the same diameter, and the Wilwood rotors match them. The only difference between them is the front rotor has smaller mounting holes...the bolts for the rotor are smaller on the front wheel. I don't have the calipers mounted up at the moment, just the front rotor bolted on. Are the rotors on your bike different sizes?
Quick Reply: Nightster Winter Makeover
