Nightster Winter Makeover
Old 12-17-2011 | 04:11 PM
Jackal's Avatar
Jackal
Just spent more...on Joker bling and fwd control extensions.
I'd have shown more of the controls, but 2" wasn't enough to clear my downtubes so TxBandit is making me 2 1/4" brackets at no charge. His CS is above and beyond and the quality is amazing for the money.
  #132
Old 12-17-2011 | 09:21 PM
PanterA101's Avatar
PanterA101
Crazy ****, lol. I'm liking this.
  #133
Old 12-18-2011 | 07:54 AM
Ergonight's Avatar
Ergonight
I'd have shown more of the controls, but 2" wasn't enough to clear my downtubes so TxBandit is making me 2 1/4" brackets at no charge. His CS is above and beyond and the quality is amazing for .the money.
Ok, I guess I can't rag on you about $. That joker machine stuff don't come cheap.
  #134
Old 12-18-2011 | 07:56 AM
Ergonight's Avatar
Ergonight
This stuff really is crazy.
  #135
Old 12-20-2011 | 12:00 PM
Ferminator's Avatar
Ferminator
Hey man....Good stuff !!!
How much would you say the rims cost to PC, if you don't mind me asking?
  #136
Old 12-20-2011 | 01:23 PM
Ergonight's Avatar
Ergonight
Hey Ferm, no problem. My guys charged me $90 per wheel. One was chrome and the other was the stock rear Nightster black wheel and you can't tell them apart now. Also, as I mentioned in an earlier post, one of the fork tubes had some minor stippling in the powder coat around the upper lip I was not happy with. They are going to redo that tube no charge. I'm keeping it for now so I can continue mocking up the bike and I'll have them redo it when they do the frame.
Trying like hell to get in the shop a few hours this week so I can assemble the front end. Don't know if I'm gonna make it but if I do there will be pics.
  #137
Old 12-21-2011 | 03:08 AM
swordy's Avatar
swordy
Big Kahuna HDF Member
dont rush things you'll only **** it up! looks like its commin together nicely. sit down have a smoke & a beer n look at it then get off ur lazy *** n finish it!!
  #138
Old 12-21-2011 | 06:48 AM
Ergonight's Avatar
Ergonight
Roger that swordy! Beer. Lots of beer. The foundation of any good mod.
  #139
Old 12-21-2011 | 12:21 PM
swordy's Avatar
swordy
yep its best to be drunk when you first get the angle grinder out! then when u get up in the morning u think someone's trashed your bike!!
  #140
Old 12-24-2011 | 09:21 AM
Ergonight's Avatar
Ergonight
Default Progress
Got some things done yesterday. Put the rear wheel back on. Left the brake rotor off for now but did put the newly powder coated rear sprocket on the newly powder coated rear wheel and it looks pretty nice. Then I went to install the front end and found out that Vulcan sent me the wrong axel. The one they sent is way to big in diameter and won't fit through the forks. So I'll have to deal with that. In the meantime, I used a piece of threaded rod to at least get the front wheel in place and get the bike on the ground. Check it out.
As you can see, I purchased new Wilwood black rotors from Scooters Performance to go with the black wheels and the powder coaters did the bolt heads. I couldn't bring myself to put the old stock rotors on those wheels.
Put the tank in place.
For now the tank is just bolted at the rear tank bracket and I have it blocked up in the front with a piece of wood. The front tank brackets have to be removed and I'll have to craft a new mounting system for the front...when we chopped the frame it moved the steering head back about half an inch and we removed the front mounting holes. So now the tank sits too far forward and the mounts hit the upper triple clamp. I'll probably chop the rear bracket and shorten it about an inch...there's pleanty of room between the rear of the tank and the seat. I also want to lower the rear of the tank so that it sits right on the frame. Due to the way the rear bracket works, when you lift the front of the tank it increases the angle at the rear bracket and raises the *** end up off the frame. So the whole tank mounting system has to be modified. But I knew that going in. It just looks kinda goofy for now. No headlight on the front adds to the goofiness.
However, I am loving the look so far. It's raked just enough that you know it's a departure from stock but not so much that it's over the top. I was concerned that raking it 4 degrees was going to lower the front end too much and I might have to buy longer fork tubes. But it's fine. The bike is definitely lower but the shorter shocks on the rear seem to have leveled it out quite nicely.
More to follow...
Elzer0 (11-28-2020)
Quick Reply: Nightster Winter Makeover
