I'm in the process of tucking all wires under the tank (2.5in lift) on my 2008 Nightster... BUT, I can't figure how to unplug that frickin' wire!! Theirs no plug or what ?!
If you did it, can you explain to me (with pics plz!) where the hell that wire unplug!
Follow that wire under the bike on the right side, behind the frame just past the right foot peg there is a connector
+1....goes to your neutral switch behind the sprocket cover. As Barry said...there is a connector under the frame near the mid-frame on the throttle side.
I had to remove my sprocket cover, my wire was solid all the way up to the connection behind the cover. I cut the ties followed it up and removed it using a ninety degree needle nose plier (very small pair). It's a bear but I thought I can't let it go take your time and do it right.
