Post your dyno sheets
RE: Post your dyno sheets
That's pretty good for a vanilla conversion with 883 heads.
You probably aren't imagining that part. The 883's have lower compression so I think the 883 ignition module has a more aggressive advance curve. Usually best power is made with the most advance you can give it without it pinging (not always though).
You might be able to. What that dyno sheet shows you is a wot run so it's using the main jet. You might get more bumping up the main jet to 175 or even 180.
to be honest the 883 ignition I had on before this dyno run felt like it made the bike run a little stronger but maybe I'm imagining it.
I think I can squeeze a little more hp and torque out with some tuning...to be continued
Finally got my sheets scanned in. I got my rpm numbers wrong when giving you guys the details on the runs...sorry...I was trying to remember what it looked like without seeing the sheet.
My baseline-883R with stage I A/C(cover removed) and SE II slip on's and rejet (bought the bike set up this way)
1200 upgrade- 1200 cylinders,pistons, ignition module. Screaming Eagle heads w/aftermarket cams(not sure what kind though), push rods. SE II slip on's and stage 1 A/C(cover removed) with same rejet from 883 setup. I think it needs to be rejetted.
And here are some pics of the bike since I haven't posted any since becoming a member.
my brake light/turn signal mod
2004 1200 Custom. S/E A/C, carb jetted 45/185, Daytona Twin Tech ignition, and V/H Straightshots HS.
cost just under 300 for the dyno and tuning work. The blue line is the baseline before carb work.
Dave
[IMG]local://upfiles/23428/F97477AEFC454F5697841873B4C8B254.jpg[/IMG]
Dave
