Boyesen TWINSHOT CV40 Kit
Installed on wife's '06. Impressive upgrade - simple swap - "THE" quintessential CV40 mod!
- Machined to exact tolerances for improved performance/reliability
- Patented QUICKSHOT 3 technology for precise/consistent fuel metering (QS3 chamber completely fills with fuel, eliminating trapped air in system, for accelerated fuel delivery)
- 25% more fuel capacity plus added bleed capability allows for solid fuel delivery 100% of the time
- Dual Check Valves, new ball & spring system keeps fuel dirt from clogging system, second valve located at sprayer for immediate response of fuel spray
- "ON THE FLY" external leak jet adjuster maximizes fuel volume/duration of squirt for all conditions (turn out for hot days/high elevations - turn in to enrich for cold days/low elevations)
- SS plunger rod & 5% stiffer activation arm spring for consistent spray response
- Precisely angled Twin Hole Sprayer enhances fuel velocity/atomization for increased roll-on acceleration
- Removable main jet cap for quick access tuning
- Predictable, smooth, instant throttle response - similar to EFI
- Improved low end performance, quick cold starts, no more hesitation/bog/stalling/backfiring
- Boyesen Unconditional Guarantee - complete refund if not 100% satisfied
http://www.boyesen.com/twinshot-vtwin
http://www.hotbikeweb.com/tech/1004_...t/viewall.html
HDF Tech
06-25-2005 11:15 AM
