Brake lights are constantly illuminated.
Old 10-24-2011, 12:47 AM
jckazz333's Avatar
jckazz333
jckazz333 is offline
Default Brake lights are constantly illuminated.
Whats going on everyone?!
As I was riding with a buddy of mine he noticed that my brake lights were not working. After I took a look I noticed that the lights are staying constantly illuminated even when I am not applying the brakes. The filament on one of the bulbs burnt out and attached to the other filament, which I am guessing could have caused a short some where. Where are the brake switches located (2009 Iron)?
Any feed back would be appreciated.
Old 10-24-2011, 06:57 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
If you have changed bars or something recently, the switch plunger may have been broken off for the front brake handle. It is very small and fragile.
Old 10-24-2011, 08:16 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
Yep. If for any reason you have opened up the right side handlebar switch housing, very likely the brake switch was broken. If you didn't place a small piece of cardboard between the front brake lever and the base, it's pretty much certain the brake switch was broken.
Old 10-24-2011, 10:19 AM
erbilabuc's Avatar
erbilabuc
erbilabuc is offline
How does this happen and do I just replace the switch? I have same problem
Old 10-24-2011, 10:43 AM
SportyPig's Avatar
SportyPig
You are most likely going to need the service manual. If you had the service manual to begin with, you wouldn't have broken the switch. Not trying to be a smart ***, that's just the truth.
Old 10-24-2011, 11:04 AM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
I had the same problem and it turned out to be a bee caught between the front brake lever & the housing not allowing the lever to return fully.
Old 10-24-2011, 12:40 PM
jckazz333's Avatar
jckazz333
I have opened up the housing. I installed drag bars recently. I do not have a service manual, probably should pick one up though... Where is exactly is this little brake switch located? I did not notice any switches when I opened up the housing.
Old 10-24-2011, 12:55 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
Squeeze the front brake lever and look into the housing, you will see where the lever contacts a bit of rubber when released, the switch plunger is behind there, you can use a flat blade screwdriver to press on the rubber and should feel a spring loaded plunger action.
Old 10-24-2011, 04:03 PM
erbilabuc's Avatar
erbilabuc
Well that didn't answer any part of my question. I have the service manual but this problem was there when I bought the bike.
So Back to original question: How does one fix this?
this is what I found in my manual and it says I must replace it?
Attached Thumbnails Brake lights are constantly illuminated.-screen-shot-2011-10-24-at-5.01.25-pm.jpg
Old 10-24-2011, 04:41 PM
cHarley's Avatar
cHarley
cHarley is offline
Seems pretty clear to me. It says to replace it, right?
Quick Reply: Brake lights are constantly illuminated.
