Seat Marks on Fender
Old 10-20-2011, 06:55 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
Default Seat Marks on Fender
I am going to be installing a spring style solo seat on my 2012 883 Iron, but right now there are "polished" spots or rub marks on the fender from the stock seat...black denim paint.
These will be exsposed when I install the new seat, any suggestions on getting rid of them?
They are surface marks only, not through the paint.
Thanks
Old 10-20-2011, 09:23 PM
Eric The Welder's Avatar
Eric The Welder
Eric The Welder is offline
cant get rid of them. once a flat black paint is "polished" it never goes back to flat.
Old 10-20-2011, 09:35 PM
barrygreen's Avatar
barrygreen
I was kinda thinking that...but some rubbing compounds or heavy scratch removers dull paint, I will try something figure it cant hurt. Just hoping someone has run into this before.
Guess I could always chop the fender and frame rails
Old 10-20-2011, 09:40 PM
wanabe's Avatar
wanabe
wanabe is offline
yup- you were right... the only possible fix would be to polish it out. a compound (probably machined on) that you work the heck out of, followed by "stepping down" in levels of polish would be the way to go. if its not into the paint you can improve or correct it. if its into the paint (or clearcoat) then you might make it a bit better but wont be able to get it new.
before you chop, you can always repaint (if polishes dont do it)!
Old 10-20-2011, 10:10 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
Fine grit sanding.
Old 10-21-2011, 08:52 AM
6sick6's Avatar
6sick6
6sick6 is offline
I have the same problem. I plan to chop that end of the fender off and roll it forward then cut off rear section of the frame and move the tail lights forward. Re-location the ECM will be necessary though. If you are interested, you can find some threads with a "how to" description around here somewhere.
Old 10-21-2011, 09:51 AM
TexFF's Avatar
TexFF
TexFF is offline
I'd be careful w/the 'denim' paint. My understanding on the denim paint is it's suppose to 'wear', or fade, like a pair of pants over time. If you use a polish or rubbing compound then your just speeding up that process & it's going to be really faded & there's no going back from that. I'd really ask HD on this one.
Old 10-21-2011, 11:11 AM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
Same thing happened to my buddies olive green nightster. There is no way to correct it and have it look right. Try lightly sanding with 2000 or 3000 grit.
Old 10-21-2011, 11:47 AM
barrygreen's Avatar
barrygreen
When the seat gets here I'm going to try a little rubing compound on a small spot.
It's really not that bad but it is noticeable. Like the seat mark on a glossy fender but the opposite.
Old 10-21-2011, 12:20 PM
joebotics's Avatar
joebotics
joebotics is offline
how about using a light coat of matching ColorRite Black Denim spray paint?... it is not cheap, but if you want to maintain your Denim paint looking good, then you better have something around to touch-up the paint .. you can scratch up the Denim finish if you look at it hard enough.. :-) ... I remember doing this (re-coating an small area with ColorRite) a loong time ago and it worked fine...
Quick Reply: Seat Marks on Fender
