Horn Placement
That all depends on how much wire you have. If it will reach, then just reroute it to the front. But, I would assume that the wiring for the horn is within the main harness that runs along under the tank, and there isn't much slack. You will need to get two pieces of wire and connect them to the wires connected to the horn and route them to the front and secure them to the harnesses with black zip-ties. Mount your horn and hook the new wires to the horn.
Here's the one I just put on my bike a few hundred miles ago...
http://www.harley-davidson.com/media...09_M_2795e.jpg
NC883 - main reason I'm replacing my current horn is it's on the fritz. So it would be a bad trade for you.
The other reason is I can't stand looking down and seeing the horn cover vibrate like crazy.
Freebird - what type of horn do you have?
gpsjr10 - just checked the wire, it's a few inches short. Thanks for the input.
