Very bad wobbling while touring.
Didn't tour before I had the 16" installed. So no way to find out. Thanks everyone, after reading so many different possibilities, what struck me is that could it be the cause of tyre pressure?
Before touring, I pumped my tyres according to the numbers stated on the tyres. And I found out after that the numbers given were the max amount of air that the tyres could hold. And for a pillion as well but I was running solo.
Could this equate to the very bad wobbling? I'm thinking of getting the tyre pressure right, and trying again to see if the bike still wobbles. Wouldn't be the best idea cause it could be dangerous. What do you guys think?
If in doubt contact your preferred tyre brand. They may have recommended pressures on their website, or email them for advice. I wrote to Avon and the maximum pressure their Venoms can be used is 50psi.
You can certainly safely use higher pressures than on your tyre sidewalls and if your tyre pressures are not high enough they will certainly badly affect handling. When fully loaded with wife and luggage I use 44F/50R with the Venoms on my Glide.
GOAT.
01-25-2017 07:04 AM
Maccam26
06-03-2009 09:22 PM
