Rough Idle... Help please?
I just bought my first Harley about 3 weeks ago, it's an '07 1200C. My problem is that it doesn't want to idle at all at startup, bottom end of each gear is extremely rough and choppy... Person I bought it from had Cycle Shack slip ons put on, but no high flow air cleaner or tuner, so I put the stock mufflers back on hoping that would solve it, but no luck. I checked dtc's today, and nothing came up, I checked all my electrical connections, and cleaned the air filter, throttle body and IAC and still didn't work. I'm going to siphon the tank dry in the morning and put some fresh high octane in. My father was telling me that the '07 sporties have fuel pump issues, and to replace the o-rings first.
Does anybody have any suggestions? I'm really frustrated with not being able to ride my bike. I'm obviously new to the forum, so even if there's info on this elsewhere, would somebody be able to send me in the right direction? Thanks in advance
wonder if the previous owner tried backing out the Base Idle Screw to make it idle low?
Some think they sound better like that, will it Idle up and then fall then die at start-up?
If so the base idle setting may be to low letting the idle fall too far before the IAC can adapt, they
are not the fastest little electric motors you know....
